Changing t3 turbo on a fez
Right later on today ill be fitting my old hybrid t3 on a mates fez thats already running a t3. I was thinking it would be easyer if i just bolt on my erst manifold with the t3 as that saves taking it off. Can i do that ?
Is there anything else i should be looking out for ? this is my first turbo swap by the way!
Yeh thats alright.....
remember to prime the turbo before you start it etc... maybe fit a new oil feed pipe and check the return pipe is ok and not blocked etc... and an oil and filter change is a must
Matt Baxter
Sep 16, 2015 08:30 PM
siscossie
Aug 27, 2015 09:27 PM
