pinto and cosworth yb head
Old Jul 6, 2006 | 05:14 PM
Phyco's Avatar
Phyco
Default pinto and cosworth yb head
can anyone tell me wether or not a cosworth head will fit onto a 2.0l pinto bottom end. im getting a 2.0l pinto for ym sapphire and was wondering if this is postible as the cosworth engine is based on the pinto 205 block. any help will be greatly appreciated
Old Jul 6, 2006 | 05:33 PM
sailorbob's Avatar
sailorbob
Yes it will, 2wd blocks were simply pinto blocks specially selected to be within closer tolerances.
Old Jul 6, 2006 | 05:45 PM
natehall's Avatar
natehall
isnt the crankshaft different?
and where can i get hold off a yb crank?
Old Jul 6, 2006 | 05:46 PM
Phyco's Avatar
Phyco
cool, chears. so i do this will i basicly have a n/a yb in my car. do u now if i would need anything else to get it running all good and proper or could i jsut bolt the head on and drive it?
Old Jul 6, 2006 | 05:47 PM
Phyco's Avatar
Phyco
and to my knowledge it wouldnt matter if it had a different crank as the crank is in the bottom end and i would be keeping the pinto botom end and jsut changeing the head
Old Jul 6, 2006 | 05:49 PM
natehall's Avatar
natehall
depends on the bhp, cos the cossie crank is 9 studded and the normal one is only 6 stud, making it a weaker unit
Old Jul 6, 2006 | 05:51 PM
Phyco's Avatar
Phyco
well i wouldnt be going for big power. jsut want to put a cam or cams in it depending on head. 4 branch manifold and bigger carb to start with. i just like the idea of having a n/a yb
Old Jul 7, 2006 | 09:31 AM
sailorbob's Avatar
sailorbob
Yes, but the question was about the block The oil pump and bearings are different too.
You see them on ebay, Motorsport News classfifieds, the parts for sale forums etc.
Not strictly, more of a 16v pinto, along the lines of the Warrior 16v pinto conversion You would probably want to change the cams to a normally aspirated grind.
Old Jul 7, 2006 | 02:26 PM
costina's Avatar
costina
Live long and prosper!!
to do an n/a conversion you will need raised top pistons to up comp ratio,some cams,twin carbs etc. otherwise it will be flat as a fart and u may aswell have stuck with a pinto
This can be costly do do it right to get around the 200 bhp mark!!!!!
good luck
Old Jul 7, 2006 | 03:09 PM
sailorbob's Avatar
sailorbob
Stock 2.0 pinto head has a combustion chamber volume of 50cc, anyone know what the YB head is?
Old Jul 7, 2006 | 07:26 PM
Phyco's Avatar
Phyco
thanks for everyones help. would i have to get a 205 block then or would any pinto lump be ok.
Old Jul 8, 2006 | 12:13 PM
sailorbob's Avatar
sailorbob
Stock pinto block sounds fine for what you're intending. I think this will be of interest to you http://www.pumaracing.co.uk/pinto.htm
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
turbotrev
Aug 22, 2015 11:41 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
