What oil for 4x4 gearbox.??????
Old Aug 13, 2004 | 09:48 AM
3drstretch's Avatar
3drstretch
Default What oil for 4x4 gearbox.??????
As title peeps.Wot oil is advised for a 4x4 mt75 gearbox.
CheeRS in Advance.
Old Aug 13, 2004 | 10:26 AM
3drstretch's Avatar
3drstretch
C'mon someone must know
Old Aug 13, 2004 | 10:30 AM
slowpoke's Avatar
slowpoke
you need special oil
i got mine from gearbox man aka bernie
Old Aug 13, 2004 | 10:32 AM
3drstretch's Avatar
3drstretch
Yeh but wot it called.Is it the same as a 2wd (ATF)
Old Aug 13, 2004 | 10:34 AM
St3V3_C's Avatar
St3V3_C
No - well, ATF is used in the transfer box, but the gbox is something different IIRC.
Haven't got the book with me to look it up sorry mate
Old Aug 13, 2004 | 10:35 AM
slowpoke's Avatar
slowpoke
no its oil specially designed for the mt75 box
says mt75 in the name of the oil if i remember
Old Aug 13, 2004 | 10:38 AM
3drstretch's Avatar
3drstretch
Cheers lads .So anyone know wot the name or code is then.
Old Aug 13, 2004 | 10:40 AM
slowpoke's Avatar
slowpoke
look on gearbox mans website it has it listed there
Old Aug 13, 2004 | 10:49 AM
3drstretch's Avatar
3drstretch
CheeRS.
Old Aug 13, 2004 | 12:23 PM
DaveEscos's Avatar
DaveEscos
fords std oil
Old Aug 13, 2004 | 12:39 PM
Stu @ M Developments's Avatar
PassionFords Creator
The oil is specifically labelled MT75 and NOTHING else should be used.
Bernie stocks it so best ya call him
Old Aug 13, 2004 | 12:45 PM
McPikie's Avatar
McPikie
Local motorfactors sold me some weird shit, cant remember what it was but it wasnt standard oil.
I am sure it was automatic transmission fluid
Old Aug 13, 2004 | 01:16 PM
Dean Saff's Avatar
Dean Saff
how often should this oil be changed?
Old Aug 13, 2004 | 08:19 PM
Eagle's Avatar
Eagle
Super Moderator
just done mine... take the plugs out and see what colour it is .. should be red .. my old box was black
Old Aug 13, 2004 | 08:40 PM
Dunccoss's Avatar
Dunccoss
You can use MOBIL SHC 75W90 its red and smells real bad
cheeRS DUNC
Old Aug 13, 2004 | 08:42 PM
its cheap enough from Fords mate, and they usually have it in stock. two types - one for the box and one for the transfer assembly.
Old Aug 15, 2004 | 02:59 PM
ian rst's Avatar
ian rst
I got some from ford cost about £11 for a litre. Y2K- i put the oil in both box and transfer didnt use a different one should i of then?
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
PeterLucas
Sep 21, 2015 11:36 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
Adam Graham
Sep 6, 2015 06:04 AM
gingeRS
Sep 4, 2015 06:29 PM
