sensor plug???? sender????
Old Jul 4, 2006 | 12:19 AM
gambit's Avatar
gambit
Default sensor plug???? sender????
have just done a major overhaul on my car but now have noticed that one little wire which connects to the cylinder head is broken (cut). its a thin wire with the same connector as the oil pressure switch, i think its for the water temperature. anyway the actual connector has broken off and i dont have it does anyone know what i should do as i went to ford and they said they dont sell it.
any advice would be much apprerciated
Old Jul 4, 2006 | 05:37 AM
antony215's Avatar
antony215
Escort Rs Turbo
Go to the scrappy and chop one off another car or some people just use a female bullet connector.
Old Jul 4, 2006 | 07:39 AM
HORNETS7's Avatar
HORNETS7
i take it the wire colour is brown with a white stripe?
if so this is the water temp sender wire!
mines gone in the same way !
get a new sender screwed into the head!
th thread on the sender unit is 4mm i got 2 brass nuts that screw onto it!
then all u do is put a crimped connector on the wire thats like a round washer then put it on the sender unit and lock into position with the brass nuts !
job done!
Old Jul 4, 2006 | 10:44 AM
gambit's Avatar
gambit
Default sender
thanks mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
