help with my brakes plz
wen i reshelled my rst, i decided to fook the abs off. so i got a master cylinder from a non abs escort, and the brake lines along with the brake distribution thing that goes on the drivers side of the engine bay, sorry i cant remem the proper name for it. anyway, im planning to have 4x4 callipers and 2wd discs all round. some1 today told me tho that my brake pedal will just hit the floor wen its done. just wondered if anyone else has this set up and if they encountered this problem. i wana make sure b4 i go and finish the braking system then find first time i try them i dont get a good system
any help will be mucho appreciated
Ive got a full 2wd set up and a 23mm cylinder and the pedal doesn't hit the floor, but they're shit!
I'd say the old brakes were better than currently.
a 25mm is really needed IMO.
cheers for the replies u two lol. yea, its a 23mm ive got on there at mo. would a 25mm be from summit like a rs2000? i'll just have to see what happens wen i get the brakes on there. if its shit, i'll look into bigger master cylinders
25mm's are only on Series 2's.
Give it a try, some people on here claim to have 4 pots and rear discs on a 22mm and apparently the pedal is spot on.
As usual its never me that has any luck but you have nothing to lose by trying
Look into it now to save you wasting your time
Mk5 Escorts 92-94 reg had 25mm cylinders (early ones had 23mm so be careful)
Most of the mondeo range in scrapyards will have them too
Have you seen the size of a Mondeo servo
You would never get one of those bad boys to fit
Ive never seen any MK6 escorts with 25mm cylinders yet. I wish i could find some!!!
oh right, and those mentioned above will fit directly onto my rs turbo servo yea? sorry if the questions i ask make me sound like i know nothing by the way. i do have a knowledge but like to get others opinions if ya get what i mean
Believe me i've tried fitting a MK5 Escort item and it will never fit in a standard servo short of cutting it and allsorts, and even then the rod inside the standard servo is far too long for the job anyway.
It would be easier to find a different servo and fabricate a bracket up IMO
