speedo cable
Old Jul 3, 2006 | 10:09 PM
rst230bhp's Avatar
rst230bhp
Default speedo cable
hello
my speedo has stoped working and am looking to change the cable
but the problem im getting is taking the old one off , how does it come off
any help will be appreciated.
thanks
rst230bhp
Old Jul 3, 2006 | 10:14 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Do you mean off the back of the speedo? It's a knack!!! Get it nice and straight, then push it in and pull it off in one movement. That's what I do. Don't force it. It must be straight though, if the cable is bent where you have moved the dash out of the way, it won't disconnect.
Old Jul 3, 2006 | 10:18 PM
rst230bhp's Avatar
rst230bhp
yeah of the back of the speedo
il try what you said tomorow, spent ages trying to figure it out
what about the other end, it appears to just be a large nut
would it be a case of just undoing both end and fiiting the new cable
thanks
Old Jul 3, 2006 | 10:22 PM
Christian and Beccy
#1 in Spelling Club
Yes, simple as that. Only tricky bit is getting it off the back of the speedo. Don't force it. It will come off, when you are being your most patient! If you get pissed off with it, go for a brew, then come back chilled and have another go!!
Old Jul 3, 2006 | 10:28 PM
rst230bhp's Avatar
rst230bhp
thanks mate
will have a go tomorow
Old Jul 15, 2006 | 11:04 PM
rst230bhp's Avatar
rst230bhp
just a quick update
got the speedo working but now for some reason the abs light doesnt
come on (abs has been disconnected) when the handbrake is on, any sensors or anything that i should
check, had to happend now, i was planning to take the car for an mot next
week, ive been told as long as the abs light comes on when the handbrake is
on, it should pass.
any info ??
Old Jul 15, 2006 | 11:23 PM
Christian and Beccy
#1 in Spelling Club
No, if the ABS is gone, its better for the light to be gone also. Alot of peeps just take the bulb out! You probably knocked the bulb or something. I wouldn't worry too much.
muz
Sep 30, 2015 08:29 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
