CHARGING PROBLEM ON MY S2.
Old Jul 3, 2006 | 12:56 PM
tezza_RS's Avatar
tezza_RS
Default CHARGING PROBLEM ON MY S2.
Hi ppl
I recantly brought an s2 as a bit of a project, and having rebuilt the engine plus a few other things i finally got it started. the battery i have did have a full charge but now it's flat as a pancake, now i'm unsure if the alternator is wired correctly or the battery is a duff? anyone got any ideas or pics of alternator wiring?
please help!!
CheeRS
Old Jul 3, 2006 | 04:09 PM
HORNETS7's Avatar
HORNETS7
right u only have 2 wires to alternator
1) solid large red which goes from alternator back to the starter and its joined there with the main batter red wire!
2) the small blue wire which is the charging status light whcih illumintaes the battery light on the clocks!
Old Jul 4, 2006 | 08:30 AM
tezza_RS's Avatar
tezza_RS
Cheers mate.
The battery light is on when i run the car from a jump start will this be a dead battery or is it that the alternator faulty or just a duff battery? i think i've got it wired right now.
Old Jul 4, 2006 | 08:44 AM
Avinitlarge's Avatar
Avinitlarge
If the battery light is on whilst the car is running the alternator is buggered
Old Jul 4, 2006 | 11:57 AM
SafeChav's Avatar
SafeChav
If the battery light is on while the car is running, firstly, the alternator won't be charging. Not necessarily because its knackered however.
The alternator uses the battery light to commence charging, if the battery light stays on for whatever reason it won't charge.
So, the alternator either isn't charging, OR, the wire has shorted to earth.
Best way to test, is unplug the thin blue wire and see if the battery light comes on, if it does, you have a short, if not, the alternator isn't charging
Old Jul 8, 2006 | 04:18 PM
white cab's Avatar
white cab
have you checked the battery with a meter 12.5 volts is good with ignition off with car running should read over 13 volts so that is how you know the altenator is charging the battery
Old Jul 8, 2006 | 04:39 PM
SafeChav's Avatar
SafeChav
The alternator WILL NOT charge if the battery light is on.......
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
