RS TURBO REAR DISC CONVERSION.
Old Jul 2, 2006 | 11:31 PM
Hyper's Avatar
Hyper
Default RS TURBO REAR DISC CONVERSION.
Hi just fitting xr4x4 calipers and discs, dilled and grooved to my S2. Got the old b*ollox stripped today when sun went down as was too hot today. Before we continue may aswell get some tips.
Do i need spacers for this conversion as my kit didnt come with any.
Will this kit sit behind standard 15s.
http://www.zetec-turbo.co.uk/ shows a picture 6th one down on the left
'Repack the wheel bearings in grease and refit the hub and clean its face, then apply some copperslip grease to the face' is my S2 hib different to the s1. It sits inside the drum right?
I have EBC grooved pads and discs up front, will i definately have to fit a bias valve to stop rears locking.
Anyone know a thread with s2 pics and details.
Old Jul 3, 2006 | 09:45 AM
SafeChav's Avatar
SafeChav
Are they the same calipers are granadas/scorpios/sierras have on the back? (and the same as in the conversion on the S1 on that site?)
The hubs are the same, the drums seperate from them.
When i did mine i used washers to space the carrier over the disc centrally.
Do you have rear apportioning valves or fixed rate ones? I run fixed rate, and so do a lot of others, alleged to be the best way to run it.
That site is pretty good i don't think there is much better to be honest
Any questions i'm sure i can help you
Old Jul 3, 2006 | 10:02 AM
Hyper's Avatar
Hyper
hi mate all i know is there xr4x4 sierra calipers, are the spacers easy to get hold off. Also i need 2 new split pins as the once that come off were rubbish. Were can i get these from. At the moment i dont have any adjustment valves the guy that sold it too me just said try it and if its not ok, he has a valve he can sell me.
Old Jul 3, 2006 | 10:04 AM
SafeChav's Avatar
SafeChav
Look at the pictures of the calipers in that S1 conversion on the site and see if they look the same. I think they are.
My spacers are just washers, if you go to a fasteners they will have thick and thin washers, mine needed one of each per bolt to get the right spacing.
Your car will have one or the other. Does it have ABS?
Old Jul 3, 2006 | 10:09 AM
Hyper's Avatar
Hyper
hi mate when you first click the brakes section they are like that. Were shot blasted and gold the same, although we painted red as it was worn. Even the bracket looks exactly the same, and i know theres a few different types floating about.
No abs left.
Old Jul 3, 2006 | 10:25 AM
SafeChav's Avatar
SafeChav
Yes they are the same as mine then.
If you have removed ABS i expect you still have the rear valves, which will cause you fun and games when bleeding them........but means they should never lock up.
The majority of people though run without the rear valves, and just have fixed rate ones under the bonnet.
Old Jul 3, 2006 | 10:39 AM
Hyper's Avatar
Hyper
Lol, What do these valves look like and where can i find them, so i need to do anything special. Also will i need to use a spacer 100%.
My kit didnt come with washers do i need these also. Thanks
Old Jul 3, 2006 | 11:20 AM
SafeChav's Avatar
SafeChav
If you look underneath the rear, you will see 2 valves hooked up to the rear wishbones (and if you don't it doesn't have them obvio ) but i can guarantee it has if the car once had ABS.
I've never known them not to need washers, otherwise the carriers foul the discs, its about 2-3mm spacing you need
Old Jul 3, 2006 | 04:11 PM
Hyper's Avatar
Hyper
Hi mate could i use washer in place of the spacers. Also what size spacer do i need to ask for exactly.
Old Jul 3, 2006 | 04:14 PM
SafeChav's Avatar
SafeChav
Blind or stupid, which are you
Old Jul 3, 2006 | 10:08 PM
Hyper's Avatar
Hyper
Thats not very nice, will let you know how i get on.
Old Jul 4, 2006 | 09:45 AM
SafeChav's Avatar
SafeChav
Ah well im not very nice so get used to it
Matt Baxter
Sep 16, 2015 08:30 PM
james kiely
Aug 28, 2015 08:58 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
