ABS lights and Brake light
Due to lack of use my 3 door has started giving problems with the brakes. The ABS and red brake warning lights are permanently illuminated and although the brakes work there is no servo assistance. I suspect the ABS pump but just wondered if anyone has easily solved the problem. Would a faulty ABS pump cause the servo not to work?
I had exactly the same problem with my old Saff but it was intermittent and corrected itself on several occasions, never got to the bottom of it.
MOT due so I need a quick fix.
David
David
Dr. Ickxs
Sep 15, 2015 10:15 PM
