Gearbox oil seals...
Hi there,
i have an S2 and have just changed the gearbox oil seal for the offside driveshaft and now oil is leaking even worse than before and i mean really dripping out. Is this a common problem? im going to change it again, do you think i just fitted a dodgy seal, it was a genuine ford one...???
just done this on both mine i used genuine ford ones too!
how did u knock them in?
best bet is to get an old drive shaft end put the seal on the drive shaft and knock it in with that!!
failing that get a large socket just under the size of the outer part of the seal !
i didnt drift mine all the way in just level with the gearbox then a further 2 mm!!
hope this helps
hope this helps
Thanks a lot for all the help, i replaced the seal again and found that the little metal ring that sits in the seal had come out, put another new seal in anyway, took more care this time and its fine now.
Thanks again for the help
TPM961
Jan 15, 2018 10:50 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Adam Graham
Sep 6, 2015 06:04 AM
