gt temp
Old Jul 2, 2006 | 08:06 PM
steven botes's Avatar
steven botes
Default gt temp
has anyone have an egt fitted to their cvh turbos ,and if so , what are your cruising , racing temps
mine were(before the last motor died) 400'c cruising and 700'c at the end of a 1/4 mile
Old Jul 2, 2006 | 08:09 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
From memory...
Cruising along motorway they are around 700c and flat out round track they were no more than 850c with ALS on.
Old Jul 2, 2006 | 09:07 PM
reality's Avatar
reality
Where are you measuring it, before or after the turbo? You want pre-turbo figures to be no higher than 850C.. If you're measuring post-turbo, then on the safe side assume a 200C temperature drop across the turbo..
Old Jul 2, 2006 | 09:11 PM
steven botes
the egt concerned is about 30cm bleow the turbo
Old Jul 2, 2006 | 10:24 PM
reality's Avatar
reality
Then that's a little too hot.. on the safe side you dont to see more than 650C where your thermocouple is..
Old Jul 3, 2006 | 01:48 PM
Tim's Avatar
Tim
MINES SAME AS TONY'S DEPENDS WHAT TURBO U HAVE T34'S SEEM TO RUN ALOT HOTTER THAN T3'S ETC IVE SEEN UP 1000 ON OVER RUN ETC UNDER LOADS 850'S MAX
Mark RS
Oct 12, 2015 06:01 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Ben26
Sep 3, 2015 07:55 PM
