Oil pump - Is it worth replacing?
Old Jul 2, 2006 | 05:49 PM
Beenie's Avatar
Beenie
Default Oil pump - Is it worth replacing?
I'm just rebuilding my engine at the moment and I'm just wondering whether or not it's worth replacing the oil pump.
I'm replacing most thing but I have no idea on how much an oil pump is gonna set me back, I just thought aswell that it's one less thing to go wrong in the long term aswell as on the hunt for more power.
Has anyone bought an oil pump recently? was it hard to fit?
Beenie
Old Jul 2, 2006 | 05:50 PM
SafeChav's Avatar
SafeChav
If you can afford it, then i would say its always worth it
Old Jul 2, 2006 | 05:53 PM
antony215's Avatar
antony215
Escort Rs Turbo
If you doing a rebuild then get all new part's i say as you dont want it to fuck up when just spent out a load of money and oil pump's are easy to fit when the engine is out
Old Jul 2, 2006 | 07:25 PM
DazC's Avatar
DazC
An engine rebuild will always include a new oil pump. Otherwise it's simply an engine refresh.
I would fit a new oil pump to be honest.
Old Jul 2, 2006 | 07:42 PM
steven botes's Avatar
steven botes
dont take a chance if the motor is out , replace!
the haynes manual says the pump cannot be removed in car - rubbish
you just need to remove one of the corners that foul against the body when you remove it - shit job though
i personally replace the gears inside the pump on every rebuild ,
although you need an impact screwdriver to get it to pieces
Old Jul 2, 2006 | 09:13 PM
Beenie's Avatar
Beenie
any idea on how much they cost?
Old Jul 2, 2006 | 09:25 PM
PeteS2RST's Avatar
PeteS2RST
I was told £69.50 from Burton's about 3 months ago when i looked at replacing mine due to low oil pressure. luckily it was only a switch that cost less than a fiver.
big_Rad
Sep 15, 2017 09:36 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
Dubs44
Aug 21, 2015 02:42 PM
