operationg temp
Old Jul 2, 2006 | 08:05 AM
Rs_Dave's Avatar
Rs_Dave
Default operationg temp
on my s2 it runs 80c - 100c+ and the fan is running most of the time, i have a 82 degree thermostat which i thought mite help bt it didnt. i dont no if it is the origanil engine if so, its got 12000 on the clock, would u say the engine is on its last legs?
any help is most appricatied
Old Jul 2, 2006 | 09:26 AM
James Raby's Avatar
James Raby
I'd say, flush the water system out PROPERLY
By this I mean, properly flush rad with a hose from each end about 5 times, also stick a hose in the thermostat and bottom hole in block this will make sure any blockage gets shoved out of the way
Refil with correct mixture water/ant-freeze and let fan cycle run 3-4 times
Old Jul 2, 2006 | 09:50 AM
zippyobrien's Avatar
zippyobrien
what water temp gauge have you got, and where does the sender fit?
im looking into getting one my self
cheeers
Old Jul 2, 2006 | 10:14 AM
Hyper's Avatar
Hyper
Hi mate i wouldnt say tour engine on your last legs just becuase of that. If your running the incorrect oil in this wether remember that will also cause tempreture to rise like that in this weather. Especially if its too thin.
Old Jul 2, 2006 | 02:58 PM
SafeChav's Avatar
SafeChav
Without sounding rude.........if you are running an 82 degree stat do u expect to see coolant temperatures less than than the temperature the stat opens at
Old Jul 2, 2006 | 06:36 PM
Rs_Dave's Avatar
Rs_Dave
i done an oil change just a week ago using mobil 1 15w 50.
i think i may have a different tempture sender alloying the fan to run 4 longer, my mates says it may be off a cossie.
is this possible??
Old Jul 2, 2006 | 06:51 PM
Rick's Avatar
Rick
Yes it's possible.
80-100 - which is it?! Thats a big difference. 80 is far too cold, and 100 isn't a worry if it's in traffic in this weather.
Old Jul 2, 2006 | 07:49 PM
steven botes's Avatar
steven botes
my own xr3 turbo runs at 85'c most of the time
i replaced the standard fan with a 12" flat type , much better cooling now , but then again , we have temps up to 35'c in summer
my car does not like running hard in these temps , prefers the cooler nights
try running some rad cleaner for 100km and them flush with a garden hose , this job is a lot easier with the rad out.you should see plenty of muck flush out , this stuff clogs up your rad and leads to increased running temps
Old Jul 3, 2006 | 09:24 PM
rstdave's Avatar
rstdave
Slightly off topic i know but does anyone know what temperature coresponds to the standard gauge in the car i.e when it's sittin at halfway what temperature is it likely to be approximately????????
Old Jul 3, 2006 | 11:01 PM
Hyper's Avatar
Hyper
Was gonna ask same question.
RS's...u've gotta love em...but mine's usually broke!!
Join the club !
Old Jul 4, 2006 | 09:44 AM
SafeChav's Avatar
SafeChav
The way i see it, out of the red section is all good
If its in the red, somethings wrong
Old Jul 4, 2006 | 10:33 AM
Rick's Avatar
Rick
lol, exactly.
As for what corresponds to what, it's guess work as they aren't calibrated.
Old Jul 4, 2006 | 10:51 AM
SafeChav's Avatar
SafeChav
If you're that concerned about temperatures then you need to pull your wallet out and buy a nice expensive and accurate gauge.
To be honest though, as shit as factory fitted gauges are, they are enough to know when things are ok, and when they aren't........
Old Jul 5, 2006 | 07:13 PM
steven botes
just below half corresponds to +-80'c on my Autogauge temp guage,
ive fitted extra everything
oil temp
water temp
oil pressure
air fuel
egt
volts
always good to have extra at 2 bar!
Mark RS
Oct 12, 2015 06:01 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Ben26
Sep 3, 2015 07:55 PM
