T3 TURBO??
Old Jul 1, 2006 | 08:30 PM
BIGEVILRTS's Avatar
BIGEVILRTS
Default T3 TURBO??
ok guys i need to find out from your guys that have a t3 turbo and when it comes on boost im tryin to find out if mines a t3 or not i cant see anythin written on it without taken it off and i cant be bothered to do that yet, so the situation is my turbo is boosting at 4k at 18-20psi and the acuator is fine and there are no air leaks i had it checked so let me know guys thanks
Old Jul 1, 2006 | 09:09 PM
steven botes's Avatar
steven botes
difficult to saywithout taking the pump off
on the side of the turbine , you will see 0.48 in raised lettering on the casting
on the compressor side , you will see 0.42 , also on the casting
this would be a std t3/t3
regards
Steven Botes
Old Jul 1, 2006 | 09:15 PM
Rick's Avatar
Rick
steven botes
No offence, but ur wrong lol
The turbine (exhaust) housing is marked on the inside - where the flange meets the manifold.
Secondly - an RST turbo is 0.36 as std - cossie T3's are 0.48.
You are correct about the compressor housing - 0.42 A/R - the same on all RS T3's. How ever, the compressor wheel is different - 45 trim on an RST, 55 trim on a 2wd cos, 60 trim on a 4by cos.
BIGEVILRTS
Only way to know is to take it off. Boost at 4k could be a wild or incorrectly timed cam, or a 48 rear housing.
Old Jul 1, 2006 | 09:50 PM
JimmyBoy's Avatar
JimmyBoy
It could be partially down to the cam.
Rick - How can you tell if the turbo is off?, im interested to know.
Old Jul 1, 2006 | 10:49 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Turbine housing size is usually stamped inside the housing, just beneath the flange where it bolts to the manifold.
Old Jul 1, 2006 | 11:03 PM
JimmyBoy's Avatar
JimmyBoy
While my RS was on the road, it dont hit full boost until about 4k, I put it down to having a piper 285t2 cam, and probablly in need of a good setup.
Been off the road for god knows how long now!
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
