White smoke from my cossie!!
Old Jun 30, 2006 | 06:31 PM
bigal344's Avatar
bigal344
Default White smoke from my cossie!!
Hello all, just rebuilt my cossie and got it started up, and i've got alot of white smoke from the exhaust whilst its running, more so when it warms up, is this gonna be the turbo, cause i'm bloody sure it ain't the head gasket, it hasn't used any water and its clean and fresh still in the header tank and under the rocker/in the oil.
Any ideas?
Old Jul 8, 2006 | 04:27 PM
white cab's Avatar
white cab
is it over fueling? can you smell the petrol in the fumes
Old Jul 10, 2006 | 01:14 PM
bigal344's Avatar
bigal344
Yes, it was overfuelling, have sorted it now though.
It was a mixup with the wiring on injector no.1 which basically meant that it wasn't pulsing the fuel but was just pouring it in, all solved now, just had to drain the oil and run it up with some cheap oil and drain again due to petrol contamination straight into the oil, still not as bad as some of the possibility's i suppose.
bobsworth
77
Mar 24, 2016 09:30 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
