fuel pump+pressure screw prob.
Jun 28, 2006 | 02:49 PM
This is for a S1.
I need to change my fuel pump, but i cant undo the nut on the metering head to release the fuel pressure.
is there any other way to do this?? otherwise the fuel will just spurt out when i undo the pump.
i need my fuel pump changed.......if i cant get the screw turned how much would a moblie mechanic charge to do the job????
Jun 28, 2006 | 03:37 PM
Leave the ar for a few hours, then just undo at the pump. Juts have a rag handy, it won't release that much.
Jun 28, 2006 | 04:13 PM
Or pull the fuel pump relay out and turn it over.......
Jun 28, 2006 | 05:35 PM
then put it back, and never have it work in quite the same way again
Jun 28, 2006 | 08:53 PM
Quote:
You reckon?
same as running out of petrol......and not like the pump is running dry either, just relieves the pressure
Jun 28, 2006 | 08:57 PM
Don't mean that - the relays always seem to go a bit tempremental.
oooooooohhhhhhhhh, i seeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
