Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
mk1 escort rst?
Old Jun 28, 2006 | 12:04 AM
mk1_4dr's Avatar
mk1_4dr
Default mk1 escort rst?
is it possible. cvh sierra gearbox perhaps, has anyone heard or seen owt like it before?
Old Jun 28, 2006 | 07:30 AM
Tigran's Avatar
Tigran
From memory the cvh uses the pinto block, if that is the case then should not be too much work.
P.S. anything is possible with a big enough circular tool
Old Jun 28, 2006 | 10:39 AM
mk2tim's Avatar
mk2tim
yes it possible but not much point, cheap ways to get the power, cvh isnt a pinto block, there is a reply on old skool ford mate
Old Jun 29, 2006 | 01:27 AM
mk1_4dr's Avatar
mk1_4dr
this is the base of the project
[/img]
Old Jun 29, 2006 | 01:32 AM
mk1_4dr's Avatar
mk1_4dr
i just want a reliable 150bhp and a dump valve, is that so wrong.this pic is when i bought it. the starmags are gone (7x13s and standard arches)and the chav sunvisor has gone ive got some better pics when i find em they will be on here.
Old Jul 3, 2006 | 01:40 PM
mk2tim's Avatar
mk2tim
pinto turbo would b a better and cheap option
Old Jul 5, 2006 | 11:31 AM
Retro Al's Avatar
Retro Al
RWD IS KING
what tim said
Old Jul 7, 2006 | 12:52 AM
mk1_4dr's Avatar
mk1_4dr
whats involved, is there anyway i can upgrade without having to enlarge my trans tunnel? im keeping all of my old parts should i ever want to put it back to standard.
Old Jul 7, 2006 | 12:54 AM
mk1_4dr's Avatar
mk1_4dr
crap, i need to figure out those buttons in the reply box. im sure you can work out what i meant tho. lol
Old Aug 2, 2006 | 08:50 PM
rosie's Avatar
rosie
u can fit a cvh into a mk1 escort & im pretty sure u can use any of the gearboxes.
u will have 2 make up mounts for the engine
also u have the problem with the dizzy as this will be faceing the bulkead & will require mods. unless u go with a efi rs turbo engine as u can bolt the coilpack anywhere.
heres a pic of an rs turbo engine in a capri
Old Sep 1, 2006 | 11:10 AM
se mk3 cabbie's Avatar
se mk3 cabbie
you can use 1.8 sierra cvh bottom end cant you with rst head etc
Vincereese
Jun 1, 2023 09:14 AM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
dlwarrior
Aug 5, 2015 10:19 AM
