S1 RS Turbo replacement uprated front tension struts
Direct replacement front tension struts made from thick walled CDS tube, solid adjustable link fitting to TCA, high quality rosejoint with all necessary hardware. Eliminates that "unavailable" Ford front joint and the inherrent weakness of the original tubes (which usually bend where they have splits at the front end edjustment clamp). The solid bush to the TCA guarantees perfect control and positioning of the TCA and therefore the castor settings. Finished in black powder coating.
£195 a pair, in stock now for immediate despatch.
Martin 07837 721986
Martin 07837 721986
Hopefully I will be collecting a batch from the powder coaters tomorrow so will do a pic then and post on here.....I have lost all my original pics when the PC recently failed!
Martin
Martin
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
155lee
Aug 14, 2015 11:21 AM
track.focus'd
Aug 12, 2015 05:53 PM
hope you did`nt lose all your work mate
