senders for early warning lights???????
Old Jun 26, 2006 | 08:26 PM
stu21t's Avatar
stu21t
Default senders for early warning lights???????
i want to put some warning lights in my dash,
one for when the water gets too hot and 1 when the oils too hot,
any1 know where i can get these senders from?
think auto, rally design... dont do em, nor do most other places ive tried.
id like the water one to be a M10x1 thread if poss as i bought an adaptor for the pipe with this thread.
also what other lights would you have? ive already got 1 for low oil pressure.
ive got the gauges but you cant always see them creep up if your driving and a big light on the dash would be a good early warning.
Old Jun 27, 2006 | 10:49 PM
stu21t's Avatar
stu21t
any1?
Old Jun 27, 2006 | 10:50 PM
Rick's Avatar
Rick
u wont get a sender to do it, u need some circuitry to condition the signal.
Old Jun 27, 2006 | 11:49 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Defi gauges can be programmed to give you warnings IIRC
Old Jun 29, 2006 | 08:32 PM
stu21t's Avatar
stu21t
why cant i do it?
its the same as a rad fan switch, the switch will make onthe fall once it reaches a certain temp.
but instead of turning on a rad fan it will turn a warning light on.
but i cant find a rad fan in a 10mm thread.
Old Jul 3, 2006 | 03:09 PM
xrtc's Avatar
xrtc
https://www.burtonpower.com/default....=15009&PSet=98
IainRS1700T
Sep 25, 2015 06:44 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
fuzzy
Sep 4, 2015 10:11 PM
