discovery real time extra
but back inthe day would a 4be saph cossie been worth that as a bent car (bent as in physically bent, not bent as in a 9 bob note bent)?
you could have broken it for more than the parts were worth and you still would have had a cossie shell you could have flogged with the log book
the rear end wasn't as bad s they made out, a bit of a rear ender but nothing that a bit of time wouldn't sort
the bonnet just needed the rubber screwing in a bit, a whole 30 secnds, if you include opening the bonnet and closing it again to make sure it looks right
the front door is another fairly simple fix by alighning it propelry
and the biggest bodge of all was his 3 finger test, with the steering not being straight
