General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
rs1800 u mite as well turn away as they are insurnce group 15 ai think and a turbo is 16 lol , get a 1.6 mk3.5 16v fiesta and drop a 2.0ltr cheap and fun !
prob is i dont know anywhere near me that would be able to do specialist work like engine swaps otherwise id put a big engine in me KA!
big engine little car big fun!
can drop the 2.0ltr in to a mk3.5 fiesta si with the lest prob out of every other car , you dont need no specail tools i did it and im 17 was 16 when i did mine lol
what if i tuned the engine in the zetec s?
likely power? what would i have to put in to get it?
4-2-1 exhaust mainfold and nice system pref with a sportcat
The right cams for the job ( pm for details ), raised rev limit and a remap. With any luck will see 140-150 bhp. I'd recommend a phase two Z-s as the cam follower arrangement is more stable at higher rpm. However the cams are an arse to fit as the valve clearances need to be set with ground 'top hat' shims, so theres a bit of work to do there.
All that with T'bs you'd be seeing 170-180 plus, but you'd need a few bottom end revisions and new management
sound good for a little car! how much would that little lot cost du think?
for cams 4-2-1, zaust remap etc i'd budget
Cams £4-500
Zaust £270
4-2-1 £270
Sportcat £200
Cam fitting, valve clearances set properly with ground top hat shims - £3-400
Custom remap - not an off the shelf chip - £4-500?
So at least the thick end of two grand if not more.....you could go ARP rod bolts for safety but you wouldnt be revving lots more over standard unless you went the TB and wilder cams route
