what mpg you getting???
Old Jun 25, 2006 | 07:42 PM
turbo.jon's Avatar
turbo.jon
Default what mpg you getting???
As above what car you got and what mpg are you getting on your fuel?????
also 1 stupid question how many litres do u get in a gallon????
cheers
jon
Old Jun 25, 2006 | 07:43 PM
S3an's Avatar
S3an
Old Jun 25, 2006 | 07:47 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Approx 300 miles to a tank with a mixture of steady m-way driving, stop start in town and spirited driving in between (sapphire cos 4x4 stg 1).
Old Jun 25, 2006 | 07:49 PM
Doug's Avatar
Doug
Thought 1 gallon was 4.55 ltrs ?
Esco's stg 3 msd
did 148 mile on just under Ł13 worth of fuel
Regards Doug .
discodenkelly's Avatar
discodenkelly
bounce, bounce, bounce
I get about 300 miles out of mine, same as frog, mixture of driving steady, too and from work occasionally and battin' fook out of it every once in a while MSD stage 2 4x4 saff
Old Jun 25, 2006 | 07:51 PM
S3an's Avatar
S3an
stage 3 escos Ł55 of super is lucky to return 160 miles. but depends on how you drive it. drive like a pussy and i would imagi ne 250/300 may be possible
Old Jun 25, 2006 | 07:53 PM
gus's Avatar
gus
im getting just over 60 mpg in my 1.4tdci fiesta which is nice
Old Jun 25, 2006 | 08:24 PM
S3an's Avatar
S3an
Esco's stg 3 MSD
Regards Doug .
so you are saying you will do more than 600 miles on a full tank?
50 mpg on a stage 3 escos
Old Jun 25, 2006 | 08:45 PM
It's Czech Mate's Avatar
It's Czech Mate
Zetec-S fiesta, filter and magnex
Lifetime mpg of the car since I owned it 38 mpg. Returns over 40 on long m way cruising
Old Jun 26, 2006 | 08:34 AM
Graceland's Avatar
Graceland
Team HOTHOT!
on the cossie (dark greens, t34, 24psi, closed loop,) - regularly saw 26 to 30mpg
with the omega 2.5 TD, see about 30-40 mpg
Old Jun 26, 2006 | 08:39 AM
B16's Avatar
B16
I thought it was 4.54, not wanting to split hairs
Old Jun 26, 2006 | 09:29 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I get 160 miles to a full tank (47 litres).
We don't have closed-loop running yet though.
Old Jun 26, 2006 | 09:33 AM
It's Czech Mate
WTF is the point in some of you saying you can get x mile to a tenner? Or I get X miles per tank
How on earth do you know how much u get from a full tank??? Do you run till you empty the tank and splutter to a halt
Please quote MPG or it's pointless answering!!!!
To get MPG brim the tank and set the trip to zero......drive.......note your mileage and brim with fuel again...note how much fule it took to refill...now u can work out your mpg
Old Jun 26, 2006 | 09:34 AM
Christian and Beccy
#1 in Spelling Club
Jeeeez, I didn't realise he wanted military precision.
Old Jun 26, 2006 | 09:47 AM
Christian and Beccy
#1 in Spelling Club
"Well, I filled my tank on 15th of June, in the year of 2006. The temperature was 21.5°c with an ambient barometric pressure of 1011mbar. Using my calibrated fuel measuring equipment, which fits inline with the fuel displacement facility at my local BP, I imparted 45.63 litres of fuel. Upon my return to the same filling station on the 24th of June, some 9 days later, I put 43.19 litres of fuel into the tank. However, on that day the temperature was 19°c, although the barometric pressure was the same. I can hereby conclude that my vehicle covered 163.25 miles on 43.19 litres of fuel, making a combined average of 3.78 miles per litre of fuel."
Hope that's OK.
Old Jun 26, 2006 | 10:01 AM
Jonzy's Avatar
Jonzy
Trip computer says 23-25mpg usually, maths works out about 27mpg. Cars in sig.
Old Jun 26, 2006 | 10:23 AM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
Hope that's OK.
FPMSL
Old Jun 26, 2006 | 10:24 AM
DaveEscos's Avatar
DaveEscos
32 mpg
It's Czech Mate
Hope that's OK.
He did ask for MPG you sarcy cunt
Not 55 miles to Ł3.47 which means fuck all
Old Jun 26, 2006 | 10:25 AM
Lo@der's Avatar
Lo@der
Sorry 11-12mpg 4wd cossie on dark greens ect. 24psi(peak)
Old Jun 26, 2006 | 10:43 AM
Rossco's Avatar
Rossco
Our Standard (filter and exhaust) on a run will do 30mpg
My Peugeot 307 HDI does 50ish MPG
Old Jun 26, 2006 | 10:51 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the 24V granny sees between 13 and 17 mpg in and around town
on the motorway it sees around the 33 mpg mark
the trip computer is just about spot on give or take a few 10ths of a ile lower than the trip meter says in the speedo cluster
with a mixture of motorway and town it's more along the lines of about 22 mpg
i did a trip back from nottingham once though, in which i recorded a 77.8mpg full tank to full tank (or whatever you figure it out as with 130 miles coverd in 7.88 litres) in my dohc sierra with the ultra low diff and slip streaming a lorry at 55 mph
the same trick doesn't seem to yeild as good a result in the granada though, but you do see upto about 45 mpg on the trip computer as opposed to about 33 mpg when not tailing a lorry
also had a few hire cars, a fiat panda with an auto box returning more than 50 mpg in town adn another one i can't quite remember the name of returning 66
on the other hand, i was lucky to see 160 from the 60 litre tank in the estate and once did 18 miles and used 22 litres of fuel
Old Jun 26, 2006 | 11:44 AM
frog's Avatar
frog
Chill out man
Ł3.47 in today's fuel money is around 3.47L, so 0.75gal, which is therefore approx. 73mpg, easy
My 300mls to a tank is approx. 22.6mpg
Scientifically (fill up, run, fill up), I get 25mpg.
If you're going to worry about 3mpg, you shouldn't really run a performance car, driving style will make either of those figures swing by at least 5mpg either way
In my opinion, there are seriously thirsty cars (below 20mpg), thirsty cars (below 30mpg), average (below 40), and seriously uncool above 40mpg
Old Jun 26, 2006 | 02:47 PM
Eagle's Avatar
Eagle
Super Moderator
on the track around 5-7 mpg
but driving like richpon on the roads made it to bridgend from newbury and back on 1 tank
Old Jun 26, 2006 | 02:49 PM
James-W's Avatar
James-W
i got my merc 270 diesel up to 70mpg last week, but usually averages at around 50-60
Old Jun 26, 2006 | 02:52 PM
Beach's Avatar
Beach
Stole the words from my mouth
If i fill up im looking at about 200 miles mixed driving, about 165 if it gets deathed everywhere
Old Jun 26, 2006 | 04:20 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Between 20-30mpg.
Does depend on how i drive but get about 25mpg on average.
Steve.
Old Jul 1, 2006 | 09:11 AM
Jimboxr4x4's Avatar
Jimboxr4x4
Over 30 mpg on a run and about 22 mpg around town. The 24v is actually slightly more ecconomical than the 12v.
Old Jul 1, 2006 | 11:51 AM
big_wig_074's Avatar
big_wig_074
30-40mpg depending on how hard im driving (never seen less than 300 miles on 38 quids worth of petrol)
Old Jul 1, 2006 | 12:04 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
bmw 320i
will do a MAXIMUM of 40 to a tenner,.....normal driving
oh, and i cant be RSed to work it out in mpg
Old Jul 1, 2006 | 12:19 PM
DaveyBoyS1's Avatar
DaveyBoyS1
Series one : never checked.
Focus ST170 : 220 mile to 45L of optimax driving steady... ford say 31mpg but in reality it nothing like that [/list]
Old Jul 1, 2006 | 12:30 PM
SortedCossie's Avatar
SortedCossie
cossie - late teens
clio 172 - 34mpg
fiesta 1.25 - 45mpg
Old Jul 1, 2006 | 12:48 PM
Jim Galbally's Avatar
Jim Galbally
about 15mpg
Old Jul 1, 2006 | 02:36 PM
wimwerf's Avatar
wimwerf
i did 504km (315miles) on a 60litre of 98petrol with my 4wd saph on stage 3 without closedloop...
for mattrs1600i...yes the petrol tank was very empty...
Old Jul 1, 2006 | 02:43 PM
Steve200+'s Avatar
Steve200+
A fwe I can remember :
406 2.1TD - 45mpg
BMW 525TDS Touring - 43mpg
Nova TD - 60mpg
VR6 Golf - 18mpg
4wd Cosworth, Stg3 - 17mpg
Bentley Mulsanne S - 12mpg (if driven like nun)
I take great pains to work it out, I need to get out more
Old Jul 1, 2006 | 03:28 PM
roybacer's Avatar
roybacer
I drove to Sheffied and back during the week in the clio and averaged 39mpg
Usally around 34/35/36 mpg depending on how i drive
Old Jul 1, 2006 | 05:29 PM
ryzetec16v's Avatar
ryzetec16v
i get around 40 mpg with my 1.6 escort on a long run but only get 30 round the town
Brickhouse
14
Oct 3, 2015 07:28 PM
Spiky
12
Aug 3, 2004 07:44 PM
Phil
Jul 19, 2004 01:13 PM
Andy_R
Jun 2, 2004 04:01 PM
