efi 3i to efi turbo
Old Jun 23, 2006 | 01:59 PM
Jt.'s Avatar
Jt.
Default efi 3i to efi turbo
Right, got a efi 3i and a series 1 bottom end, if i put the 3i head and inlet on the turbo bottom end and used frst loom and ecu will it work? i think i need a 1.8 crank pulley and sensor but what managment do i go for OFAC or OFAB? whats the difference and what else wil i need to change?
Cheers ppl Jt
Old Jun 23, 2006 | 08:42 PM
SafeChav's Avatar
SafeChav
Ok, you have the right idea. Personally though if its out of the car i would drill the block and fit the proper CPS, the EFI flywheel will be 220mm aswell, where as s1's have a 200mm flywheel. So thats an added bonus.
Plus the fact the 1.8 bottom pulleys are rather large and have minimal clearance, and you also need the alternator bracket and alternator or pulley, aswell as the cam cover.
You can run either management, OFAB is said to better, using the marelli type MAP sensor which can be upgraded to 3 bar.
If you run OFAC, there is one wire to be cut, if you run OFAB you also need to change 2 wires on the ECU plug, and change the plug for the MAP sensor. Simple as
Old Jun 23, 2006 | 09:33 PM
mathewwebber's Avatar
mathewwebber
I have a mint OFAC ecu and a 165 chip if you need one give me a shout. But OFAC is the easier way to go and what I use on my ORST.
Old Jun 24, 2006 | 08:10 AM
SafeChav's Avatar
SafeChav
It is the easier option but OFAB isn't a lot more work, its still very easy
RSmark84
Sep 13, 2015 01:29 PM
bigryrs
Sep 7, 2015 06:45 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
