S1 RST not going into gear at all! Help
Old Jun 20, 2006 | 08:00 PM
Seriesonersturbowady's Avatar
Default S1 RST not going into gear at all! Help
Hi there all, just joined I hope some one can help, I have just finished restoring my Series One after a long hard year, Engine and box fitted yesterday and lubricants in today,. When I start the car and try to select a gear the lever is just refused. If i select a gear and start the car with my foot on the clutch it will start but the car tries to creep foward, New clutch and recon box, both standard items, ANy ideas? Clutch does not feel nice either, car will drive how ever if started in gear but clutch has a very low biting point. If car is idling and in neutral I have no chance of getting it to select only when engine is switched off.Any help would be appreciated Thanks...
Old Jun 20, 2006 | 08:13 PM
JesseT's Avatar
JesseT
The adjuster on the clutch pedal doesn't seem to be working?
Old Jun 20, 2006 | 08:24 PM
Well I am not sure, The pedal is not clicking or anything, I put the cable onto the box and then just sat in the car and pushed the pedal and there were no clicks, do I need to remove the cable from the box end then push the clutch pedal down then re attach the cable and see if it re adjusts?
Old Jun 20, 2006 | 08:42 PM
JesseT's Avatar
JesseT
You can try to pull the adjuster wheel back with your hand and try the pedal then. Did it come backwards? Did it go back when you pushed the pedal? Sounds like there's something wrong with it. It should adjust automatically.
Old Jun 20, 2006 | 08:49 PM
The pedal is operating correctly, I have if you like a partial clutch, when the pedal is pressed the arm on the box moves so everything is moving. As I said if I start the car with it in first with my foot on the clutch down hard it will start and I can pull away normaly, but the position of the clutch pedal is very low when the biting point is reached, so would the adjuster have this much influence on the clutch movement as I am scared it may be something internal? Are you sure its the adjuster at fault would that cause this problem?
Old Jun 20, 2006 | 08:54 PM
JesseT's Avatar
JesseT
No, I'm not sure. I'm thousands of miles away, so just guessing. It can be internal if you're sure the ratchet is operating fine. Using wrong type thrust bearing or reversing the clutch plate can make something like this also happen.
Old Jun 20, 2006 | 08:59 PM
Sorry I know you are m8,just clutching at straws wanted to get this problem sorted in my head as its worrying me a little. I will try the adjuster first then it that fails to sort it will replace the cable then go from there, thanks a lot for your help Jason.
Old Jun 20, 2006 | 10:53 PM
NEWTON's Avatar
NEWTON
hi mate try an give the pedal a good yank up,the rachet just needs to set its self,had this prob on mine and did the above and all is well hope this help you
Old Jun 21, 2006 | 10:46 AM
SafeChav's Avatar
SafeChav
If the adjuster is gone you should be able to feel a looseness in the pedal, the one on my orion is going and the clutch continually changes while driving.
If you can't fully disengage the clutch the adjuster has to be gone.
Old Jun 22, 2006 | 12:15 PM
I have ordered a new cable and adjuster so will try both of these items, the clutch was working correctly before i changed the gearbox, only driven it about 200 miles, so i cant see that its the clutch. Someone told me that it might be the fork pin inside the bell housing has broken and not letting me get a full clutch, any body herd of this problem at all?
Old Jun 22, 2006 | 05:15 PM
SafeChav's Avatar
SafeChav
Its highly unlikely to be the clutch being as its so new. I'm sure someone somewhere has managed to break a fork but its not going to be very common. If that was the case, the clutch wouldnt disengage evenly and you would more than likely feel some judder. I would also expect you to of felt the fork breaking to be honest.
My money is on the adjuster
Old Jun 22, 2006 | 10:37 PM
I Hope so! both cable and adjuster will be in at my local dealer tomorow so will fit and see. Did not feel fork break, and it should not have done, its all new or re con equipment. Will post some pics of her when I am finished with her, thanks for help!
Old Jun 23, 2006 | 08:32 AM
SafeChav's Avatar
SafeChav
keep us posted
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
