Let the Rear running gear resto Begin (Part 1)
Old Dec 17, 2003 | 04:58 PM
Blakeya's Avatar
Blakeya
Default Let the Rear running gear resto Begin (Part 1)
Put the car up in the air today for the start of the rear running restoration. Unlike last winter when i restored all the front end suspension, i now have a digi camera so will share my resto with all:-
Watch this space
Andy
Old Dec 17, 2003 | 09:55 PM
3drstretch's Avatar
3drstretch
Looks like mine did.Any problems mate.Give us a shout.
How mine is now.
But it is in bits again to finish it off.Check out 'My 3dr winter rebuild'
Old Dec 17, 2003 | 10:06 PM
Blakeya's Avatar
Blakeya
Cheers mate,
I take even more inspiration from yours, looks lovely. The hard graft starts tomorrow. Bleeding knuckles etc etc, I'm sure you know the score. Mine hands are only just normal after last winters efforts on the front end
Andy
Old Dec 17, 2003 | 10:11 PM
RSrussell's Avatar
RSrussell
Gonna do mine, when i can be bothered
Old Dec 18, 2003 | 10:20 AM
3drstretch's Avatar
3drstretch
To make it easier for you.Drop the petrol tank.Disconnect the prop/brake lines.Then drop the rest down together.You'll be surprised how easy it is to do it this way.Like i did below.
Old Dec 18, 2003 | 02:08 PM
Blakeya's Avatar
Blakeya
Cheers Stretch,
That was my plan after reading the workshop manual anyway. Just one question for now:- How best to disconnect the braided brake lines without all the fluid peeing everywhere? Do you have to blled all the fluiod out of the system befors you start? This may run the ABS Pump dry??
Regards
Andy
Old Dec 18, 2003 | 02:24 PM
3drstretch's Avatar
3drstretch
Didnt have braided hoses on at the time.So just clamped rubber ones.
See if you can get a couple of little length's of brake pipe with the right end and blanked off at other.Most good car accessories/Motor Factors shop should have pipe making facilities.
HTH
Old Feb 17, 2004 | 08:38 PM
looks good m8
Old Feb 17, 2004 | 08:45 PM
keep the pics comming ,good work mate
James Porter
Aug 26, 2015 10:51 PM
155lee
14
Aug 22, 2015 12:15 PM
knight19770
Aug 4, 2015 12:36 PM
Graceland
Jul 31, 2015 10:34 AM
