Duratech engine, tapping from plastic intake manifold??
Old Jun 18, 2006 | 02:52 PM
Moonie's Avatar
Moonie
Default Duratech engine, tapping from plastic intake manifold??
A friend of mine has a 2001 model year Mondeo with an 1800 Duratech.
It's had a tapping noise from the top end ever since he bought it and recently he decided to do something about it. It sounded like tappets so he phoned Ford to price a new set. Ford said to him "have you checked the intake manifold"
They appear to be correct, with a stethoscope on the plastic intake manifold the noise can clearly be herd and more towards the cam belt end.
Anyone herd if this before or know what could be the cause. I work for Volvo and they use the 1.8 Duratech in the S40/V50 however, I have never come across this tapping noise.
The Volvo also uses the plastic intake manifold and has swirl throttles inside it. Does the Mondeo use the same system?
Anyone come across this before?
Old Jun 18, 2006 | 03:15 PM
dave_si's Avatar
dave_si
When I was working for Dovercourt earlier this year there was a Mondeo with a 2.0l duratec that came in. One of the flaps had broken off the intake manifold and caused a bit of a mess. Needed a whole new engine, which wasn't cheap.
Id advise your mate to replace the intake
Old Jun 18, 2006 | 03:25 PM
Moonie's Avatar
Moonie
Thanks mate, just needed to confirm the intake manifold used the swirl throttle flaps.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Franko99
Aug 29, 2015 01:38 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Perfmr2
Aug 6, 2015 07:30 AM
