water injection priming pump?
Old Jun 17, 2006 | 06:13 PM
Paddy rst's Avatar
Paddy rst
Default water injection priming pump?
when fitting a rear mount water injection tank what priming pump are peeps using other than washer jet pumps etc etc
av seen flojet pumps mounted next to tanks in the boot what model 12v flojet pump could be used ?? where are these pumps available from?
cheers Paddy.
Old Jun 19, 2006 | 03:39 PM
markk's Avatar
markk
i just prime with the same pump - not really sure what you mean, my pumps sit next to my tank in the back
Old Jun 20, 2006 | 03:39 PM
Paddy rst's Avatar
Paddy rst
under hard cornering the supply to the pump can be effected thus the poss need for a priming pump, also using a priming pump with the aquamist pump can up the cc to 600cc..
Old Jun 20, 2006 | 03:46 PM
markk's Avatar
markk
you would need to be pulling 3000000 g's to remove the water from a standard cylindrical water inj tank pal, and , as for upping the cc's depends on how much water your using, but id be suprised if you use 600cc of water without hydraulicing your motor mate !!
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
