FIESTA TURBO FAN PROBLEM
Hi there...
Was wondering if anyone can help regarding a problem with my bro's frst. Last night he calls me and says his fans haven't cut in and the heaters dont work inside the car
I've heard that this is a fault with them due to a relay in the fuse box is this right?
Also if this is the case do ford's stock them and does anyone know the part number??
Cheers people
Cheers people
BEHIND YOUR FUSE BOX, WHERE THE ACTUAL RELAYS SIT, THERES A GREEN RELAY WHICH IS PRONE TO BURN UP A BIT FROM TIME TO TIME.
THIS RELAY CONTROLS THE FAN, FOG LAMPS AND HEATER.
JUST UNDO THE TWO FUSE BOX SCREWS UNDER THE FUSE BOX PLASTIC COVER, PUSH THE BOX INTO THE FOOTWELL AND REPLACE THE RELAY. TEN MINUTE JOB.
HOPE THIS SOLVES THE PROBLEM.
Originally Posted by MrBroadside
On my brothers fuse board they wasn't a green relay
Got one and tried every relay still wont work at all...Board looks okish IMO...
thats not a too bad of a job of the mk3.
if your bro dont have a green relay he prob get a yellow one so get a green one and try that but norm cleaning the pins with some wet and dry or a knife and giving then a tiny and i mean a tiny bend 99.9% gets it all working again
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Zoggon
Aug 10, 2015 10:39 AM
