pectel wiring
Old Jun 16, 2006 | 04:38 PM
barry0777's Avatar
barry0777
Default pectel wiring
hi all im ineed of some wiring layout or diagrams for the pectel loom and any other info regarding it im wanting to know the pin numbers for the coil pack convertion to run her up any info pls thanks
Old Jun 16, 2006 | 10:48 PM
Stu @ M Developments's Avatar
PassionFords Creator
which coilpack conversion are you looking for teh pinout for?
Old Jun 17, 2006 | 09:27 AM
barry0777's Avatar
barry0777
hi stu im ineed of the pin out on the P8 wictch iv been told 21-26 but 26 has been taken up on the loom im left with pins
2 6 7 9 22 21 on the pectel loom have sorted ALS but not the water injection???ithinks that 20 12 but they have also been taken up??? the coil packs pluged in the two amps and i have two white wires from that plug witch are labled as pin 6 or 9 idont know witch one, and pin 26??? stu do you have any diagrams on the layoput of this set up on the loom also it has the two rings for the old system coil are these causing the probs as why i havnt got my empty pins on the main block??? dose this help ???pls let me know many thanks again!!
Old Jun 18, 2006 | 05:34 PM
barry0777's Avatar
barry0777
anyone with any info so ican run over the checks ??????
Old Jun 19, 2006 | 11:32 AM
Only your mapper can answer that question as he has assigned the pinouts.
If you havent gone with an external coildriver you will also need a new revcounter, which i assume your mapper has explained?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 25, 2015 01:38 AM
