Feza Turbo Oil Leak???
Old Jun 14, 2006 | 10:09 PM
RS HAGI's Avatar
RS HAGI
Default Feza Turbo Oil Leak???
My fiesta turbo keeps leakin oil from the sump i think! its had a new sump on it n the sump gaskets been done about 5 times now but continues to leak oil. it seems to be the same amount of flow all the time! can anyone help me here cos im gettin pissed off with it now
Old Jun 15, 2006 | 03:02 AM
TURBO BOI's Avatar
TURBO BOI
them gaskets are a coont
gota put them on dry, no sealant and make sure its not done up too tight to crush the gasket
Old Jun 15, 2006 | 08:41 AM
RS HAGI's Avatar
RS HAGI
Iv had ppl goin on about back pressure or summert sayin its a sign of a nackered engine and that it will just keep blowin gaskets???
Old Jun 15, 2006 | 12:30 PM
TURBO BOI's Avatar
TURBO BOI
if all ya breathers are blocked ect then there will be pressure built up in the crank case and yes this can cause gaskets to blow n leak
but with regarding you sump gasket i reckon its just a case of fitting it properly as like i said before there a coont, as many ppl end up making serval atemps to fit them
Old Jun 15, 2006 | 01:09 PM
RS HAGI's Avatar
RS HAGI
Cheers pal!
Old Jun 15, 2006 | 01:34 PM
TURBO BOI's Avatar
TURBO BOI
hope ya sort it
Old Jun 15, 2006 | 04:29 PM
SafeChav's Avatar
SafeChav
where abouts is it leaking? Flywheel end of the crankshaft by any chance?
Old Jun 16, 2006 | 08:56 AM
RS HAGI's Avatar
RS HAGI
From the sump i think???
Old Jun 16, 2006 | 08:59 AM
SafeChav's Avatar
SafeChav
You need to identify exactly where its leaking from. You may have blown a crankshaft oil seal or something like that.
Old Jun 16, 2006 | 09:48 AM
RS HAGI's Avatar
RS HAGI
Iv had an lsd box put init n my mechanic said he checked there n it wasnt leakin from there!!!!
SafeChav's Avatar
SafeChav
Doesn't mean it hasn't failed since the box was fitted.........
Old Jun 16, 2006 | 10:08 AM
RS HAGI's Avatar
RS HAGI
Maybe!
Old Jun 16, 2006 | 12:04 PM
Avinitlarge's Avatar
Avinitlarge
My fiesta turbo did this, Did the gasket every day, In the end we put a breather on the sump, Think it was down to the engine being wanked, Too much crank case pressure
Old Jun 16, 2006 | 05:26 PM
RS HAGI's Avatar
RS HAGI
Did it stop leakin oil then after u put a breather in the sump?
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
st220kyle
16
Aug 14, 2015 06:13 AM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
mattman1234
24
Aug 1, 2015 11:46 AM
