Repositioning Cossie Amal Valve ????
Post Miester !
I want to repostion the cossie amal valve, will prob put it on the wheel arch, does it matter how far it is away from the turbo ? or will it just pressurise the same where ever it is ??
Al....
Al....
anywhere in the engine bay will be fine, doubt youll run pipes long enuf to affect anything... i dont THINK it causes a problem will you hit 2/3+ meters (but i may rememebr wrong)
Russ Payne
Sep 25, 2015 08:29 PM
