what do i need????
Old Jun 13, 2006 | 08:03 PM
deankenny's Avatar
deankenny
Default what do i need????
went to get my wheels aligned, but the garage said no point as all the rubber has worn away on the wishbone, now what do i need, jus the rubber bit or a whole new wishbone?
Old Jun 13, 2006 | 08:12 PM
nellyscossy's Avatar
nellyscossy
wot car is it on
Old Jun 13, 2006 | 08:23 PM
deankenny's Avatar
deankenny
escort mk5 L reg
Old Jun 14, 2006 | 12:40 PM
SafeChav's Avatar
SafeChav
New arms mate
Old Jun 14, 2006 | 06:49 PM
deankenny's Avatar
deankenny
i got both new arms put on today but jesus the car is still everywhere, every pothole why wheel moves like anything
Old Jun 14, 2006 | 08:26 PM
Alvyn's Avatar
Alvyn
did u also change the link arms?
Old Jun 14, 2006 | 08:32 PM
SafeChav's Avatar
SafeChav
Have you got big alloys? Classic for making the car go all over the shop espcecially when lowered.
Old Jun 14, 2006 | 08:54 PM
deankenny's Avatar
deankenny
yeh changed both wishbone arms, yeh its lowered by 40mm and got 17" tsw razors on it
Old Jun 15, 2006 | 06:26 AM
Alvyn's Avatar
Alvyn
and did you change the 2 link arms also? people do over look them and leave them think their about Ł15 each!
Old Jun 15, 2006 | 08:52 AM
SafeChav's Avatar
SafeChav
Its a good point, but i think its going to be more the 40mm & 17's making it drive like that, its not un-common.......
Old Jun 15, 2006 | 01:29 PM
deankenny's Avatar
deankenny
lol ill get them looked at, also the alighnment centre said it also looks like a bush ahs gone on the left side??
Old Jun 16, 2006 | 05:17 PM
deankenny's Avatar
deankenny
i didnt think of it but surely after getting new wishbones and there is still like a kniockin/rubbing noise coming from front left its a wheel bearing, am i wrong?
Old Jun 17, 2006 | 11:25 AM
mk2rstaff's Avatar
mk2rstaff
jack it up and pull the wheel from top and bottom and wiggle if you have movement ha presto a wheel bearing, pressed in type so hub of and bearing need to be pulled and pushed out, you could do it with i hammer and chisel and replace the races but not reccommended
