apexi avc-r boost controller
Old Aug 10, 2004 | 03:43 PM
Paddy rst's Avatar
Paddy rst
Default apexi avc-r boost controller
Does anyone know any uk stockists of this controller and prices ?
cheers paddy.
Old Aug 10, 2004 | 03:46 PM
Rene's Avatar
Rene
bren @ apex-performance(.co.uk)
Old Aug 10, 2004 | 03:48 PM
Jon ERST S2's Avatar
Jon ERST S2
I saw them on ebay some guy sells them and the greddy ones.
I heard they are a nightmare to setup. Look pretty good though!
Paddy rst's Avatar
Paddy rst
cheers
Old Aug 10, 2004 | 03:49 PM
Paddy rst's Avatar
Paddy rst
yeah they do look the business...
Old Aug 10, 2004 | 03:50 PM
gurnE's Avatar
gurnE
Heard the same thing, absolute pig to set up!
Had the Greddy Profec B-II recommended by a couple of tuners so went for that one
Very impressed
Old Aug 10, 2004 | 03:51 PM
TILLIO's Avatar
TILLIO
try simon @ warrior 01473 831521, as he gets stuff from g"rasshopper"
If not try nemisis performance in colchester
Old Aug 10, 2004 | 04:09 PM
Jon ERST S2
yep I looked at the Greddy. Only thing stopped me was I was broke
Old Aug 10, 2004 | 04:14 PM
Paddy rst's Avatar
Paddy rst
any pics of the greddy one or web site to check them out..?
Old Aug 10, 2004 | 04:24 PM
Jon ERST S2
http://www.greddy.com/
Old Aug 10, 2004 | 04:38 PM
Paddy rst's Avatar
Paddy rst
nice 1
Old Aug 11, 2004 | 03:51 PM
BLACK DOG 2's Avatar
BLACK DOG 2
GOT ONE THAT I TOOK OF A CAR NOW IN ITS BOX 07711068237
Old Aug 11, 2004 | 03:53 PM
rsnissan's Avatar
rsnissan
they are not hard to set up at all. Its having the correct feeds for the unit on bespoke applications thats the problem. if you can sort them then the AVCR will be fine.
Old Aug 11, 2004 | 03:57 PM
Paddy rst's Avatar
Paddy rst
so avc-r can be used fine on a rst??
Old Aug 11, 2004 | 04:01 PM
rsnissan's Avatar
rsnissan
Well you can use it on ANY turbo car to control boost in a closed loop system i.e it will moniter boost and adjust accordingly to deal with spikes etc....................in order to use ALL of the functions it also needs a TPS signal an RPM signal and a Speed signal. It will also display the inj Duty as well if you can get a signal for that.
In order to do Gear V's boost you need the TPS, RPM and Speed signal.
Not sure what the RST has signal wise and weather you can substitute some via tinkering about i have just come over from the dark side so not up on my RS stuff yet
Old Aug 11, 2004 | 04:13 PM
Paddy rst's Avatar
Paddy rst
ok m8 cheers for that.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
