suspension for a track car
Old Aug 10, 2004 | 02:59 PM
Gra's Avatar
Gra
Default suspension for a track car
whats a good suspension for a track car, its only an S2, not mega powerful as been taking advice to get used to the track etc before going mad on power. But now pretty much all is done, but i am not sure on suspension. not sure how much to lower it etc, or just keep standard springs with koni's on a hard setting or standard shock and lowering springs good? dont wanna get into spending loads on coilovers etc, as once its finished there is a possibility of it going to fund a cossie track car,
cheers
Old Aug 10, 2004 | 03:02 PM
Ryan's Avatar
Ryan
koni's will be fine.
Old Aug 10, 2004 | 03:03 PM
Gra's Avatar
Gra
cool cheers
Old Aug 10, 2004 | 03:14 PM
CabrioTurbo's Avatar
CabrioTurbo
wont go far wrong with Koni's! and a 25-40mm drop although not THE BEST they are a good compromise as they are relatively (compared to coilover etc) cheap and perform/last well.
You could use new standard suspension and a 25mm drop but round a track i imagine it would still be very whallowey
Old Aug 10, 2004 | 03:48 PM
Scott R's Avatar
Scott R
I found with Koni's on the S1 round the track it needed slightly better springs than those that came with them, go for a stronger spring rate/poundage, and you should be fine.
saph in dorset
Aug 14, 2015 10:10 AM
RIB1122
Aug 13, 2015 09:09 PM
dal3door
Aug 13, 2015 06:55 AM
RIB1122
Aug 3, 2015 09:20 AM
Old ford
Jul 31, 2015 06:50 AM
