Comment of the day
ROTFPMSL
Pikie: My whhel bearing is fucked on the 3i, I cant be arsed to sort it til weekend.
Lad at work: Can you not just use the wheels off the cab then?
On a serious note tho, will it be OK to 'nip it up' until weekend??
Guest
Posts: n/a
fookin strange how the fronts just go bang with no wiring first mine were that fooked after a drive to scotland the brakes failed on the last 20 miles as the calipers couldnt grip the disks as they were wobbling that much
i hate wheelbearings knockin the caseings out pain in the ass
Losen 4 wheel nuts
Jack car up
Remove wheel nuts
Remove wheel
remove 1 screw (if its even there) retaining drum cover.
remove 1 Hub nut
Remove hub
fit new bearing.
refit in reverse order.
Job done.
Piss of piss
Either on the drive on a a fookin mountain
Jack car up
Remove wheel nuts
Remove wheel
remove 1 Hub nut
Remove hub
fit new bearing.
Job done.
Piss of piss
I bet you the stub axle is fucked
i drove mine round for about a month with it whining like fuck.. finally got my mate to put a new bearing in (after prising the old one out
) he said it 'should' be ok.. but it needs a new stub axle really, about a mile down the road the fucker collapsed
had to have a new stub axle and they aint fucking cheap for what they are1
Originally Posted by * Rudey *
ryan what yer method for getting old bearings out as this can take fooken ages?
i use a socket and hammer watch not to score the caseing
mk3ste
Oct 17, 2021 10:09 AM
deathrider666
Sep 28, 2015 06:12 PM
