ABS warning light on, 2wd Cossie.
Old Jun 11, 2006 | 08:38 AM
simonc's Avatar
simonc
Default ABS warning light on, 2wd Cossie.
ABS light goes out after about 15 secs of starting the car but comes back on as soon as you go over about 18mph. I removed the front sensors & cleaned them but i may be wrong in that i only cleaned the ends of the sensor & greased the outside metal drum bit, i'm wondering if that is an earth or something maybe i shouldn't have greased it.
Any help appreciated.
Simon.
Old Jun 11, 2006 | 08:41 AM
Dave Henshall's Avatar
Dave Henshall
could be one of the back sensors...
also could be a speed inballance in the wheels, is one tyre significantly more worn than the others, or are the fronts worn more than the backs etc....
Old Jun 11, 2006 | 07:36 PM
simonc's Avatar
simonc
no probs with tyres,all about 5mm. Will check the rear sensors in the next few days.
Simon.
Old Jun 12, 2006 | 10:18 AM
foreigneRS's Avatar
foreigneRS
Testing the future
you need a bright shiny earth where the sensor screws into the hub
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
dojj
15
Aug 18, 2015 08:21 PM
