Volt meter and water temp gauges.
Old Aug 10, 2004 | 11:14 AM
McPikie's Avatar
McPikie
Default Volt meter and water temp gauges.
The volt meter just has a black and red wire to the back and the water temp has the same. Are these for illumination then?
How do I hook them up?
Old Aug 10, 2004 | 11:16 AM
Jim Galbally's Avatar
Jim Galbally
black = earth red = live
wire em up to the lights feed as then it'll only light up wen you turn the lights on
Old Aug 10, 2004 | 11:19 AM
McPikie's Avatar
McPikie
Yeah Jim, I know that, but how do I get them to measure volts and temps??
Old Aug 10, 2004 | 11:30 AM
Jim Galbally
oh...
well with just 2 wires... you cant (on the water atleast)
you'd need at least 3...
1 for ilumination live, 1 earth, 1 feed
unless ofcourse the bulb is seperate in your gauge n those wires are not ilumination ones...
i assume the voltmeter could use 2 wires n share the feed with the + illumination, but thats a wank way of doing it... n doubt even TIM are that rubbish...
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
