2wd oil pressure relief spring
Old Jun 9, 2006 | 11:19 AM
montecos400's Avatar
montecos400
Default 2wd oil pressure relief spring
My 2wd cos has just developed a problem,
If I start it all I can hear are very loud tappets but after 5-10mins it goes. But intermittently it will come back and then go away??
I am guessing the pressure relief spring in the oil pump is sticking or has an issue but the pump is brand new and covered 1000 miles??
Any advice before I replace the pump. I have replaced the lifters and it is exactly the same.
Old Jun 9, 2006 | 11:22 AM
is it a ford oil pump m8 ?
Old Jun 9, 2006 | 11:43 AM
montecos400
It was from Graham Goodes,,new HP oil pump 2wd.
Old Jun 9, 2006 | 06:43 PM
jon@work's Avatar
jon@work
Before taking the engine apart, it may be worth spending a few quid on a cheap oil pressure gauge, and seeing what happens when the noise returns. Ford want about £30 for the sump gasket and seals, so may be cost effective if you can get a gauge for less.
You did fit the gasket between the pick-up pipe and the pump didn't you ?
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
