Will 4WD head fit 2WD???
Old Jun 8, 2006 | 07:23 PM
chavez's Avatar
chavez
Default Will 4WD head fit 2WD???
Hey guys my saph 2WD head is split and im looking for another one(not with ease) Ive been told that a 4WD will fit as long as its complete with cams as the only diff is the cam fixings and the thermostat for a 2 bolt to a 3 bolt would this be true ??????????? cheeRS guys Donni.
Old Jun 8, 2006 | 08:34 PM
cossie350's Avatar
cossie350
Nowhere to bolt the turbo damper on mate Also the turbo feed is fed from the head instead of the block.....
Old Jun 8, 2006 | 10:50 PM
jon@work's Avatar
jon@work
will raise compression ratio slightly also - you'd be better off finding a 2wd head
RUBY123
Oct 22, 2023 12:04 PM
3i Jim
Nov 20, 2015 05:12 AM
turbotrev
Aug 22, 2015 11:41 AM
markk
18
Aug 17, 2015 05:19 AM
lockie
Jul 31, 2015 10:03 PM
