measuring pcd?
Old Aug 10, 2004 | 08:59 AM
Default measuring pcd?
Which way do you measure a wheels pcd??
sorry to appear a dumb woman!
Old Aug 10, 2004 | 09:00 AM
cossymad's Avatar
cossymad
middle of bolt hole to middle of bolt hole on 4 stud- easy to do
If it's 5 hole let me know.....and have a calculator ready
Old Aug 10, 2004 | 09:38 AM
St3V3_C's Avatar
St3V3_C
Middle of OPPOSITE boltholes
Old Aug 10, 2004 | 09:40 AM
cossymad's Avatar
cossymad
Old Aug 10, 2004 | 09:42 AM
St3V3_C's Avatar
St3V3_C
Old Aug 10, 2004 | 10:09 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If it is for your Cossie, it is 4 x 108mm...
Old Aug 10, 2004 | 11:07 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Easiest way to accurately measure 4-stud PCD is leading edge of stud hole to trailing edge of opposite stud hole.
As Mike says, 4-Stud Fords are 4x108.
Old Aug 10, 2004 | 11:16 AM
foreigneRS's Avatar
foreigneRS
Testing the future
in case you don't know what it is, it stands for Pitch Circle Diameter and is the distance from the centre of the wheel to a circle that runs around through the centreof the bolt holes.
hth
as already said, it's 4 x 108mm on virtually all fords except granada, scorpio etc that have 5 bolt holes.
Old Aug 10, 2004 | 11:29 AM
The wheels are 18" multifit if that makes any difference?
Old Aug 10, 2004 | 11:34 AM
discodenkelly's Avatar
discodenkelly
bounce, bounce, bounce
I've got multi fits on mine Nik, they're designed to fit different cars, hence multi fit, Mine have pcd's of 4x108 (ford etc) and 4x100 (VW etc).
It should say somewhere on the rim what the pcd is, unless you can test fit one to make sure they fit.
Old Aug 10, 2004 | 11:52 AM
Can't find it on the wheel anywhere. I had these on my cossie...yep tis true!! mainly at the time a case of having to! wheel clearance was fine...probably due to the fact my car has aspirations of being a vauxhall Frontierer after having such a close relationship with one last year!! ( anyone got any reasonably priced lowering springs!!?)
But the bumpy Island roads offered far too much competition!! lol!
So I'm selling them, and have been asked stupid questions like pcd! and will they fit on my Rover 400!
hence the thread!
Old Aug 10, 2004 | 11:57 AM
discodenkelly
Here ya go Nik, this should have all the pcd''s ya need so you can advise people what will and won't fit
http://www.tyresave.co.uk/fitments.html
Old Aug 10, 2004 | 12:06 PM
Old Aug 10, 2004 | 12:15 PM
Ima-Racing500's Avatar
Ima-Racing500
Nik...dont be sorry for appearing dumb...you cannot help it
Old Aug 10, 2004 | 12:28 PM
cossymad's Avatar
cossymad
Generally multi fit wheels are as follows
4x108/ 4x114.3 (ford and early jap)
4x100/ 4x108 (rover, honda, mazda etc And ford)
That will not help you.
Tell me the wheel and all codes & markings from the back.
Rover and ford have different centre bores aswell so you'll need a set of spigot rings to rover (56.1 or 64.1mm) to fit in the wheel to centralise them on the car properly.
Old Aug 10, 2004 | 02:12 PM
Phil...please behave long enough for me to conduct a serious albeit trivial thread, and then I will devote so much more time to ridicule you in the other one! promise!
I will have a look at the wheels later and post everything I can find on them, in fact if my blonde, female, insignificant brain will allow me to remember I'll charge the batteries for the digicam and take a pic!
tankybaby66
Feb 6, 2016 02:24 PM
Mikersturbo
Sep 27, 2015 07:43 PM
cossynut2
Aug 19, 2015 11:29 AM
Alloy wheels and ICE for sale
Aug 16, 2015 07:55 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
