Ford Non RS / XR / ST parts for sale. All Ford Car parts in here. (Non RS / XR / ST ONLY please) Starting a topic requires you to have purchased a gold membership.
1630cc high spec FWD crossflow, now on ebay
Old Jun 7, 2006 | 02:29 PM
datar18's Avatar
datar18
Default 1630cc high spec FWD crossflow, now on ebay
Ok, this all really needs to go now as i have things to pay for. /too many messers on parts.
The engine cant be heard running as has never been run before, if you need to see it with the head off, then so be it.
Head and internals,
it has steel rocker posts, and new everything, it was acid dipped and rebuilt fully with brand new parts. Also had an unleaded valve seat conversion so for better use for modern day driving.
Brand new block internals,
with over sized to 1629cc, high compression pistons, everything is lightened and balanced, . over sized thrust bearings and big end bearings, Kent BCF3 cam. Basically the whole thing has been acid dipped and re-built with all new seals and bearings, new timing chain, new crankshaft sprocket, new rockers and shaft etc etc etc
It has a standard mk1 xr2 carb on it at the moment also, the carb in the picture is not included ()
It has brand new Magnecor leads including the king lead, brand new water pump, all new gaskets and oil filter. A brand new Felpro head gasket advised as being correct for this over bore by Burton power, with receipts and ARP head studs and nuts. they cost me enough alone.
I want £450 ono and collection only. Everything is new and very high spec.
Old Jun 8, 2006 | 01:38 PM
datar18's Avatar
datar18
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=8073631093
happy bidding people!
Old Jun 21, 2006 | 10:49 AM
datar18's Avatar
datar18
bumpety bump
Old Aug 17, 2006 | 04:44 PM
bigad4x4's Avatar
bigad4x4
Are you selling it? or is your mate using YOUR ID
again
Remember full s/s exhaust you oh sorry your "MATE" WAS SELLING and
the money that was sent to
your so
called "MATE" STOLE from redrsturbo
Still no money back or signs of an exhaust
If buying off this username be carefull guys
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
jessie_rs
62
Aug 6, 2019 09:27 PM
Kam B
Sep 24, 2015 10:40 AM
RSmark84
Sep 13, 2015 01:29 PM
