ECU
Old Jun 7, 2006 | 11:42 AM
GazzaG's Avatar
GazzaG
Default ECU
if you disconnect this fron the engine will it still start no problem
a freind said that if you disconnect the ECU the car will be alot faster
But will it also be easy to steal
Help please
its a 1998 mk6 escort 1.6 zetec
Old Jun 7, 2006 | 12:49 PM
robbyridz's Avatar
robbyridz
i think you have had your leg pulled by your mate
it wont start without ecu, the ecu controls almost everything on zetecs. from fuel pump, to starter, injectors, idle, etc
thus the easy to steal bit would be incorrect coz u would have to tow it but yes, the Passive Anti Theft system is integrated into the ECU so, in theory - if the car could actually start without ECU (which it wouldn't) it would be easier to steal.
Old Jun 7, 2006 | 01:47 PM
Dave Henshall's Avatar
Dave Henshall
as as far as making it faster, was he doing this... the drop in weight may help, but it definately wont run at all without the ecu
Old Jun 7, 2006 | 04:37 PM
GazzaG's Avatar
GazzaG
kk cheers lads
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
