Adj. TCA/Comp Strut and anti-roll bar Question
Old Jun 6, 2006 | 06:00 PM
granth's Avatar
granth
Default Adj. TCA/Comp Strut and anti-roll bar Question
So, what's generally done regarding anti-roll bars when upgrading to adjustable TCA and compression struts like Comp Brake sells? Just elimination in the front or is there something I'm missing here?
Old Jun 8, 2006 | 09:54 PM
Basky's Avatar
Basky
you still can run your anti roll bar with your comp struts i was told
Old Jun 9, 2006 | 09:36 PM
rinus_2005's Avatar
rinus_2005
That's indeed getting rid of the arb. Tough i would be interested in a compressed strut kit, which would relocate the arb.
Old Jun 10, 2006 | 08:25 PM
Mr C's Avatar
Mr C
Yeah Comp brake stuff does away with the ARB totally, but I have seen other manufacturers still running a front ARB in conjuction with Comp struts via drop links on the TCA and the ARB bracket welded to the bottom of the Compstrut bracket, I will post some pics, I dont know which way to go and who will do what parts for the best results either?
What do you want your car to do?
Old Jun 10, 2006 | 08:40 PM
Mr C's Avatar
Mr C
Std ARB with Adj TCAs
Some different Comp strut AND ARB combination, the bracket is actually on the Strut not the TCA
And also Martins Escos has comp struts and Adj TCAs and a front ARB to follow, I would be interested to know how and where this will fit and the benifits too (pic in FAST FORD) I believe his parts are ZooMotorsport gear
Old Jun 12, 2006 | 08:07 PM
granth's Avatar
granth
This is for a rally car project.
Thanks for the pics. What other manufacturers are making these? (Other than Compbrake?)
Old Jun 12, 2006 | 08:45 PM
K.Goa's Avatar
K.Goa
Rallydesign stock compressionstruts and an ARB to be mounted in front of the TCA`s, I`d definently go with this kit, you may also choose in 3 different strenghts for the ARB.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
