Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
2.8i gearbox to pinto which clutch and could we use 2.8 prop
Old Dec 16, 2003 | 08:27 PM
fatboyz's Avatar
fatboyz
Default 2.8i gearbox to pinto which clutch and could we use 2.8 prop
hi as most of you know we are fitting a pinto in a mk 2 escort and fitting a 2.8i capri box and axle does anyone know what clutch to use and if i can use the 2.8i prop aslo does anyone know exactly what we will have to do to the input shaft on the 2.8i box ? cheeRS
Old Dec 17, 2003 | 02:32 PM
I was under the impresion that the 2.8 box woul snot fir as the input shaft was to long u woul dbe better of just fitting a sierra box in as it the same just the input shaft is diffrent you can pick one up for Ł50.
As for clutch you can run a std. clutch up to about 125bhp at the wheels for every day use.
As for prop I think the capri prop is to long if you send me the mesurement you have I will check it against my RS prop for you.
Old Dec 17, 2003 | 03:08 PM
fatboyz's Avatar
fatboyz
from what i have been told is that the ratios in the 2.8 box are very very good ( 1st to forth same as old rs1800. but what i ment about the clutch is which bits to fit ie from 2.8i box to pinto , disc cover etc ? cheers for your info
Old Dec 17, 2003 | 10:28 PM
MickB's Avatar
MickB
I've got a 2.8 gear box in my mk2,i had the input shaft changed for one the right lengh and used an uprated pinto clutch,the 2.8 one is to big,the capri prop aint no good either,to long,u want one of a rs2000 or of a auto escort or buy a single piece one,about Ł100ish new.
Hope this helps.
Cheers Mick.
Old Dec 18, 2003 | 07:40 AM
fatboyz's Avatar
fatboyz
Default hi mick
hi mick what axle do you have as we are going to use the 2.8 box and axle but i have been told that the rear axle flange is different to the escort prop ? what input shaft did you have fitted ? was it difficult how much did it cost ? and who done it ? cheers Dave
Old Dec 18, 2003 | 12:30 PM
Did not realsie that the gear ratio was diffrent as I have always run a straight cut box.
And by the way Merry Christmas to all in Old Skool
Old Dec 18, 2003 | 09:50 PM
MickB's Avatar
MickB
Hiya,
i use a 2ltr capri back axle and a single piece prop,rocket to atlas was the one i got.
Took gear box to my local gear box place,they stripped it checked it and rebuilt it with correct lengh input shaft,dont no wat it was from though,cost me Ł90.
Old Dec 19, 2003 | 07:43 AM
fatboyz's Avatar
fatboyz
Default cheers mick
thanks for the info mate i will have to ring round some places to get a quote as we need the box rebuilt anyway cheers again
Old Dec 19, 2003 | 07:44 PM
http://cgi.ebay.co.uk/ws/eBayISAPI.d...category=21654 a prop on ebay
Old Dec 20, 2003 | 07:53 AM
fatboyz's Avatar
fatboyz
cheers rpm i saw it last night and sent him some questions to see if it will be the one for what we need cheers again
Old Dec 20, 2003 | 09:25 PM
fatboyz's Avatar
fatboyz
hey rpm do you yhink this is the prop we would need 2.8i box to 2.8i axle as the chap selling it dont know sh*t
chowfornow
14
Jan 5, 2019 09:01 PM
Daniel Howard
Oct 3, 2015 10:44 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
