Fiesta Cosworth
Old Aug 9, 2004 | 06:26 PM
whitneyd's Avatar
whitneyd
Default Fiesta Cosworth
Does anyone have info on putting a cossie lump into a MK1 or MK2 Fiesta. I'm toying with the idea but want to do my research first.
Old Aug 9, 2004 | 06:30 PM
cfoster's Avatar
cfoster
was quoted to do a PROPER job this afternoon including wishbones etc etc... Based and Autocross car and your looking at about 20k. You could probably do it a bit cheaper but then you will most probably run into problems...
HTH
Chris
Old Aug 9, 2004 | 06:32 PM
Escort_Cos's Avatar
Escort_Cos
AVA in scotland done a fiesta with cosworth engine. may be worth asking them for some information
Old Aug 9, 2004 | 06:37 PM
whitneyd's Avatar
whitneyd
I figured even with only 300hp is should move pretty good with the power to weight ratio.
Old Aug 9, 2004 | 06:43 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
would spin like a bitch i reckon, if your serious and gonna go for the track look, cage stripped interior etc etc, you have to get it all set up proper, and for near 20k for the conversion engine transmision tunnel etc etc, would it be worth it unless your loaded?
Nick-T's Avatar
Nick-T
AVA built a front wheel drive Mk3. For a rear wheel drive, talk to Steve Scott at A1 or Sean and Brom at Zoo. Either of them could probably do something for you
Old Aug 9, 2004 | 06:54 PM
whitneyd's Avatar
whitneyd
I'd have to do the conversion myself. Which will save a lot of cash. but I'd like to look at some of the ones done already to give me an I dea of what has to be done. I have a donor Sierra so I have the tunnel and floor if I need it. Like I said I'll start looking into it. If anyone has pics or links to pics I'd appreciate it. Thanks
Old Aug 9, 2004 | 07:09 PM
Sexy-RS's Avatar
Sexy-RS
HTH
Chris
There trying to pull your pants down i had a mk 3 fez rwd, had all the fabricating done by hi-spec when they was into it and work also done by A1 and it wasn't no where neare that
Old Aug 9, 2004 | 07:25 PM
Andy_R's Avatar
Andy_R
A few pics of Azifs Mk3
Old Aug 9, 2004 | 07:44 PM
whitneyd's Avatar
whitneyd
Anybody got pics of a rear wheel drive one?
Old Aug 9, 2004 | 09:05 PM
Sexy-RS's Avatar
Sexy-RS
Here's mine that is still sitting in a lock up Is a minter and a proper sleeper!!! will hopefully have it sorted soon and back on the road as it was mine and an ex's its difficult As the shell ws his byt the conversion paid for by me But he has no interest in getting it back on the road after i blew it up!!! So i got to sort something out i wan this beast back in my hands
Old Aug 9, 2004 | 09:08 PM
McPikie's Avatar
McPikie
Old Aug 9, 2004 | 09:09 PM
Pornstarr's Avatar
Pornstarr
What about that MK1 Fiesta that was in Classic ford a few months ago?! Red un, with a Pinto and RWD!?
That's recently been converted to Cossie!
go lookin in the mk1/2 section on xrtwo.com
Old Aug 10, 2004 | 07:48 AM
andyescos's Avatar
andyescos
Yep, loads of rally cars have been done like this, You use (as above has) mk2 cross member and steering rack, wack in a pedal box and 5 link the back like a mk2.Has anyone used a cossie diff in the back instead of the Mk1/2 5 link set up?
and do you have to knock up custom ARB for the front, can you use compression struts?
Cheers, Andy
Old Aug 10, 2004 | 08:59 AM
PF Ben's Avatar
PF Ben
Speak to Steve Scott at A1 Rally Sport mate - he's doing my RWD Fez, which uses Cossie running gear and front suspension / brakes / hubs etc. and a Watts linked Baby Atlas with Mk2 Group 4 suspension out back- exactly the same as what you want mate... I'm running a CVH in it but will prob swap to a Cossie at a later date...
Ł20k? NO WAY MATE! Speak to Steve...
Cheers,
Ben
Old Aug 10, 2004 | 09:03 AM
Rolls's Avatar
Rolls
Good god, there all at it lol!!!!
Old Aug 10, 2004 | 09:31 AM
Bomber's Avatar
Bomber
Rolls - we'll keep the fwd spirit alive mate
Old Aug 10, 2004 | 11:07 AM
Sexy-RS's Avatar
Sexy-RS
Cheers, Andy
All the running gear on myine was cossie
JoeyBoyden
Jan 4, 2024 02:36 PM
Bosch
Aug 23, 2015 12:31 PM
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
