Oil consumption Cossie 4x4
Old Jun 5, 2006 | 07:13 AM
captiva's Avatar
captiva
Default Oil consumption Cossie 4x4
Hi Canada calling
Can anyone throw some light on my problem? I have a 1991 Cossie 4x4 with only 113,000 kilometres genuine (no doubt) which burns more oil than it should. It seems it is worse under hard driving, no smoke to speak of but seems to consume 1 pint to 500kilometres, no oil leaks, engine in good original shape. I am thinking it may be breather system or PCV valve if it has one or could the turbo be losing it through the bearing but then I would see smoke. If I rev the engine quite high when stationary I get a small amount of blue smoke mixed with black but nothing that would give me this consumption.
Being in Canada I have no where to go with this one as no one knows what a cossie is
Old Jun 5, 2006 | 08:38 AM
CosKev3's Avatar
CosKev3
Hi m8,
If you use the search feature on this forum you will find a lot of posts about Cosworth oil consumption
Ford quoted upto a litre of oil could be burnt within 600 miles,depending on driving style that is quoted in the orig brochure that came with the Cosworth
Old Jun 5, 2006 | 08:52 AM
TurboShed's Avatar
TurboShed
Cossiemodo
That sounds just like my Cossie, drinks oil but doesn't smoke.
Old Jun 5, 2006 | 11:43 AM
Csm's Avatar
Csm
fookin snap
it was sometimes putting out small amounts of smoke butim thinking the breather catch tanks and pipes may be choked a little ,im gonna have a look today at mine
Old Jun 5, 2006 | 03:01 PM
costina's Avatar
costina
Live long and prosper!!
same as
DixieTheKid
Jul 23, 2023 10:16 AM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Old ford
Jul 31, 2015 06:50 AM
