Really need help
Fitted stage 3 bits at the weekend, when i started the car, it was missing on cylinder no 4 and white/grey smoke pouring out the back that stinks of fuel. I have swapped the injector and plugs for that cylinder and also checked for a spark with the ht lead out still no joy, please help as i was hoping to have it ready for Rally Super Car day on sat
when i fitted all my stage 3 bit's the only place i drove was to the tuners to get the fueling sorted.
have you put a 3bar map sensor on?????
check it is ok???? wire's on and vacum is ok....
I swapped the injector and spark plug over to a different cylinder and the problem was still with cyl 4. I have put map sensor on I will have to check that, will it run with the standard map sensor on just to check?
