fuel ajustment on the metering unit (S1)
Old Jun 3, 2006 | 03:12 PM
biglee's Avatar
biglee
Audio specialist
Default fuel ajustment on the metering unit (S1)
hi peeps, does anyone know how to ajust the fuel on the metering head for more fueling on boost as mine is a tad lean, AFR meter saying very lean on boost....oppps.
its only doing 12.5 psi......so it should cope with that.
i turned the boost down to 8psi and its still a tad lean.....
and please dont just say GO AND GET IT SET UP, as i want to learn this myself,,,
cheers my fellow ford lovers....
Old Jun 3, 2006 | 03:28 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Seriously, is it worth doing an engine, thats the hard way of learning!
Old Jun 3, 2006 | 03:40 PM
SafeChav's Avatar
SafeChav
Its not very easy Lee, u can do adjustments to the hydro electric pressure actuator, and you can do the vacuum pipe to pressure regulator mod, neither of which i would have a stab at and hope for the best
Old Jun 3, 2006 | 03:59 PM
Rick's Avatar
Rick
It's electo magnetic pressure actuator u pleb
Hydro - does ur run on water
And go and get it setup - ur gauge is next to useless...
Old Jun 3, 2006 | 04:00 PM
SafeChav's Avatar
SafeChav
Hydo - does ur run on water
Hydo?????
HYDO?????
Who's the pleb now, BITCH
Old Jun 3, 2006 | 04:02 PM
Rick's Avatar
Rick
ahem, edited,
SafeChav's Avatar
SafeChav
I never thought it would come to this, but you are actually, ULTRA QUEER.
Whats Electo???
Is that something to do with selection
Old Jun 3, 2006 | 04:04 PM
Rick's Avatar
Rick
im going back in the sun...
Old Jun 3, 2006 | 04:08 PM
SafeChav's Avatar
SafeChav
Are you sure thats wise
Old Jun 3, 2006 | 07:02 PM
biglee's Avatar
biglee
Audio specialist
i dont have a guage i borowed a afr meter and wide band lamder sensor off of a motorsport place i know so its the bollocks.... i have the pipe system you clamp on to your exhaust which has the sensor in it and that is wired to a digital reader that tells you what the afr is,, ie lean rich ect 12.5 to 1 ect, it should be the bollocks it cost over 500 quid, lol
the thing is i want to learn how to do this and dont just want to go to a tuner and let them get on with it, i have the right kit to do it ,det headphone amp ect....
what vacume pipe to the fuel reg......how the fook does that work??? anyone got a link or sumit???
Old Oct 11, 2009 | 02:04 PM
dannydanny123's Avatar
dannydanny123
ide like to know as well without the ussual , go to a tuner im armed with a screwdriver....cmon on ..u know u wanna wheeerez the screww grrrowl
Old Oct 23, 2009 | 03:10 PM
dannydanny123
my metering unit is actualy filling with fuel...lovely.. apart from being broken does anyone know what this means and how it could be rectified
155lee
Oct 24, 2015 11:11 AM
Bransby
Sep 21, 2015 05:29 PM
rs_jim
Sep 19, 2015 08:41 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
