TIMING
Old Jun 2, 2006 | 08:58 PM
costina's Avatar
costina
Live long and prosper!!
Default TIMING
Can the timing on a cos b changed or is it written on chip?
On efi pintos the loom had a connector which by earthing wires retarded ignition 4,6,8, degrees
Any ideas
Old Jun 3, 2006 | 02:43 PM
richm's Avatar
richm
yes there is a similar retard function on cossies, the connector(s) is near the main ECU connector, hanging out of the ECU loom, one pin will be earth, the other two you link to earth singly or both together to provide the varying degrees of retard.
Old Jun 4, 2006 | 09:47 PM
foreigneRS's Avatar
foreigneRS
Testing the future
pins 13 and 14 on the ECU
check that it works with a timing light though, as this is not enabled in all aftermarket chips.
Old Jun 5, 2006 | 02:47 PM
costina's Avatar
costina
earth out pins i presume
cheers nick
Old Jun 5, 2006 | 03:08 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
cheers nick
Nope, just making contact between pins will advance/retard, well, that's what Mark @ MAD had me do while his head was in the engine bay checking timing
I mean, you don't earth them permanently, just temporarily to make the adjustment.
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
