WI pin number on P8?
dont you have to have a pectel board or similar to run WI?
ie it doesnt just run off the std ECU?
I think you will find you are wrong Dave and btw i don't have a standard ecu
I cant help thinking that it is better to run the water injection from the SECS monitor (only if you have one - obviousely
), for a start it is easy to adjust/set up, and you get a "run" indication for the pump.
Also, it is easy to test if the installation is actualy working by connecting temporary a spare jet poking through the bonnet vent, then lower the pump run point - say 18 PSI boost with 12 ° charge temp, then take the car on a run and observe for a nice spray of water
Doug i binned off my SECs monitor so that is not an option!
When this engine/ecu were in the rally car a wire from the ecu/loom was used to trip the water injection and i just want to make sure i connect the right one!
Can anyone confirm what Dingy has said???
Originally Posted by Rene
might be an idea to phone simon (secs) to ask him if you need to know quickly ?
There was a time when this question would have been answered quickly on here but it seems all the knowledgable people have fooked off to be replaced with kids who know fook all
PassionFords Creator
And you did have the correct answer from Steve in 32mins and written pictorial confirmation only 2hrs 58mins later which i think is pretty damn fooking good for the free information superhighway
Sorry spadge thought my reply was good enough a kid like me...
Sorry i wasn't sure on p8 but they all have same pin layout
3door's loom is connected to that management light on dashboard too....
best alter that or it will come on at 40 degrees
Dingy your reply was appreciated thank you but you said
same as all ecu's init
Pin 12 negative trip
The word init didn't inspire confidence as it told me you wern't sure!
Rich
I did not say everyone was a kid i just pointed out that a lot of the knowledgable people that used to be on here don't seem to be around much anymore but there are a lot of kids talking bollox all over the place
Stu i had no assurance that Steve's answer was correct as he didn't sound 100% sure himself so i therefore required a more definate answer which true i did get from Kev but only after i had retreived this thread from half way down the second page with my above reply!
Rich
SPADGE,
you all know he is the most important person on here and when he needs an answer he needs it NOW
spadge i suggest if you need an answer ASAP ring the turbosystems premium rate hotline ROFLOL
Originally Posted by Escort_Cos
SPADGE,
And i suggest you fook off
Rich
muz
Sep 30, 2015 08:29 AM
rsguy
44
Sep 29, 2015 03:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
